Do I have to enable some option in DVDMaestro to use navigational slider in PowerDVD?
Disable user action panel in DVDMaestro is all unchecked, but when I compile the DVD and prewiev it in PowerDVD I still can't use navigational slider.
Any ideas?
Where do I set closed GOP?
I also tryed compiling the movie (with ac3 sound and subtitles) only and it worked fine.
But when I try to include root menu and chapter menu it doesn't work. -
Powerdvd is sketchy sometines. I have made numorous fully standard dvds with Maestro and have them not play correctly in powerdvd (but fine in everything else). If you can, try another PC dvd player. The one PC dvd player i found that followed how a homedeck would play it was the "mediamatics dvdexpress". Very basic functions but if you want to see if your disc will truly work the way you want it to, run it in that--
Avidemux lag after moving the slider
By las7h0p3 in forum Video ConversionReplies: 2Last Post: 3rd Jun 2009, 11:30 -
Power DVD - no 'click slider' in version 7?
By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2008, 13:28 -
Color correction-slider for avisynth ?
By SerbianBoss in forum EditingReplies: 24Last Post: 6th Dec 2007, 17:12 -
No Audio on DVD-RAMs via PowerDVD XP 4.0
By im2020 in forum Software PlayingReplies: 1Last Post: 19th Jul 2007, 17:38
